teddyb
May 08, 2017Aspirant
Why is Volume Size below calculated?
Hi, I just had to rebuild a chassis (EDA500) from scratch. I did the following: 1. Powered down. 2. Removed drives 3. Deleted partitions 4. Inserted drives 5. Powered on 6. Selected new...
- May 15, 2017That's fine.
If you don't have any unused drive in the chassis and only one volume per chassis, then turn on X-RAID, and your volume should expand (vertical expansion).
jak0lantash
May 14, 2017Mentor
Well, irst, do you know why it's off? Is the volume encrypted?
- teddybMay 14, 2017Aspirant
It is not encrypted. So, I really have no idea why it is off. Sorry for the ignorance on the overall topic!
