teddyb
May 08, 2017Aspirant
Why is Volume Size below calculated?
Hi, I just had to rebuild a chassis (EDA500) from scratch. I did the following: 1. Powered down. 2. Removed drives 3. Deleted partitions 4. Inserted drives 5. Powered on 6. Selected new...
- May 15, 2017That's fine.
If you don't have any unused drive in the chassis and only one volume per chassis, then turn on X-RAID, and your volume should expand (vertical expansion).
jak0lantash
May 14, 2017Mentor
Well, irst, do you know why it's off? Is the volume encrypted?
teddyb
May 14, 2017Aspirant
It is not encrypted. So, I really have no idea why it is off. Sorry for the ignorance on the overall topic!
