carlocki
Jan 01, 2022Luminary
Why my nas netgear Ready NAS 104 is re-synchronizing
suddendly my nas was not working good looking to the display it is sre-ynchronizing why is happening?
- Jan 05, 2022
carlocki wrote:
i copy and paste the log but the post it has been always deleted
Likely triggered the spam filter. You can PM me (using the envelope link in the upper right of the forum page) if this happens again, as I can release spam. Or wait for a mod to get to it.
Anyway, there are no changes to the health - you are still seeing the one command timeout on each drive. I don't find that concerning, as it has not increased during the resync.
carlocki
carlocki
Successfully completed diagnostics
System
Disk 1 has 1 Command Timeouts
Disk 2 has 1 Command Timeouts
Disk 3 has 1 Command Timeouts
Disk 4 has 1 Command Timeouts
Logs
2022-01-01 14:08:53: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2022-01-01 13:08:53
2022-01-01 12:41:35: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2022-01-01 11:41:35
2022-01-01 12:18:19: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2022-01-01 11:18:19
2021-12-31 23:01:27: ufsd: "umount" (sde1): is unmounted at 2021-12-31 22:01:27
2021-12-31 16:02:46: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-31 15:02:46
2021-12-31 14:01:20: ufsd: "umount" (sde1): is unmounted at 2021-12-31 13:01:20
2021-12-31 08:02:43: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-31 07:02:43
2021-12-30 23:01:14: ufsd: "umount" (sde1): is unmounted at 2021-12-30 22:01:14
2021-12-30 17:02:44: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-30 16:02:44
2021-12-30 11:02:21: ufsd: "umount" (sde1): is unmounted at 2021-12-30 10:02:21
2021-12-30 08:02:44: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-30 07:02:44
2021-12-29 23:01:31: ufsd: "umount" (sde1): is unmounted at 2021-12-29 22:01:31
2021-12-28 23:04:42: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-28 22:04:42
2021-12-28 23:00:48: ufsd: "umount" (sde1): is unmounted at 2021-12-28 22:00:48
2021-12-28 12:17:39: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-28 11:17:39
2021-12-27 23:01:28: ufsd: "umount" (sde1): is unmounted at 2021-12-27 22:01:28
2021-12-26 21:26:37: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-26 20:26:37
2021-12-26 20:02:35: ufsd: "umount" (sde1): is unmounted at 2021-12-26 19:02:35
2021-12-26 17:02:46: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-26 16:02:46
2021-12-26 14:01:51: ufsd: "umount" (sde1): is unmounted at 2021-12-26 13:01:51
2021-12-26 10:02:47: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-26 09:02:47
2021-12-25 21:01:26: ufsd: "umount" (sde1): is unmounted at 2021-12-25 20:01:26
2021-12-24 23:25:52: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-24 22:25:52
2021-12-24 23:00:50: ufsd: "umount" (sde1): is unmounted at 2021-12-24 22:00:50
2021-12-24 16:02:38: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-24 15:02:38
2021-12-24 14:02:19: ufsd: "umount" (sde1): is unmounted at 2021-12-24 13:02:19
2021-12-23 23:10:37: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-23 22:10:37
2021-12-23 23:00:56: ufsd: "umount" (sde1): is unmounted at 2021-12-23 22:00:56
2021-12-23 13:19:57: ufsd: "mount" (sde1): is mounted as NTFS(rw) at 2021-12-23 12:19:57
- carlockiJan 01, 2022Luminary
registry
- StephenBJan 01, 2022Guru - Experienced User
I redacted the log zip file - it shouldn't be shared publicly as there is privacy leakage.
One thing you should fix is the problem with email alerts not getting through. This could be a simple password problem, but you might also need to disable two factor authentication and all "less secure apps" in your gmail account settings.
You appear to be letting the NAS reboot while the resync is in progress. Don't let that happen, it increases the risk of data loss.
thank you for you advices
you mean all the problem is about a shotdown meanwhile it was resynching?
