Zurd
Dec 24, 2017Star
Why "Resyncing started for Volume" after volume creation
Brand new ReadyNAS RN214 with firmware latest firmware 6.91. I did the formatting procedure of my 4 HDs by pushing the reset button, turning on the ReadyNAS and going into the boot menu for Facto...
Sandshark
Dec 24, 2017Sensei
Formatting and RAID sync are two entirely different things. The sync has to create the superblocks, whether there is any data present or not. Format prepares the individual drives and sync links them together.
- ZurdDec 24, 2017Star
So it's a normal 24h operation for a RAID-5 with 4 HDs of 4 TBs?
I find it unexpected because my last NAS was a Drobo, there was no need to do any sync when doing a new RAID-5 volume.
- StephenBDec 24, 2017Guru - Experienced User
Building a RAID-5 array requires computing all the parity blocks, and that needs to be done even if the volume is completely empty. The process requires either reading or writing every disk sector in the array.
I'm not sure what you saw with the Drobo, but this applies to all NAS, not just ReadyNAS.
