eeney
Sep 14, 2012Aspirant
Win 7 Drive Mapping
Hi I'm hoping this is a simple one to answer, and apologies for my possibly dumb question. I'm running a Readynas Ultra 4 Pro, I have four drives/shares mapped to a win 7 machine. I can access ...
DaddyR1
Sep 24, 2012Aspirant
eeney wrote: Solved.
Thanks for the link, after doing some more reading a found a solution.
I found a small utility to manage network mappings, basically it maps your network drives as specified, if the mapping wasn't successful, every minute it will try again to map the drives until they are successfully mapped.
I know this could be achieved through a wee batch script, and I found some VB to do this, but the utility provided a quick and easy option.
Can you post a link to the source of your utility? I have the same issue with mapped letter drives and have had the odd problem with CrashPlan not finding drives.
