lact
Feb 24, 2020Aspirant
Windows Previous Versions Not Working (Already Read Other Threads)
Hi All, I'm traditionally a Synology user, using ReadyNAS for a few Egnyte deployments and one particualr thing is driving me nuts. Really hoping someone on this forum can help? We have our ...
- Mar 06, 2020
Hi lact,
NETGEAR support will also inform you the same that you will need to contact Egnyte since it worked with the non-ELC shares. It is something to do on how Egnyte manipulates the shares modules. You may inform them that Windows Previous Version works on the non-ELC share.
If you have an Egnyte case number, you can send it to me via private message. We will try escalating it to Egnyte.
lact
Mar 03, 2020Aspirant
per my original post, I have tried this already :)
- I also tried it without "Allow Snapshot Access" since some post somewhere mentioned that, but it didn't help either.
Sandshark
Mar 03, 2020Sensei
Is System Protection enabled in Windows? I don't know if local drive and network drive "previous versions" are tied together, and I can't test it without deletng all restore points on the PC.
