mike_
Jul 30, 2012Aspirant
WOL problem on NVX
I am trying to use the WOL function on a NVX If the NAS powers down, either by pressing the power button or using the built in power timer, then the WOL works if the packet is sent within a few min...
Slasky
Aug 02, 2012Aspirant
Which port have you forwarded? There are some different opinions or options out there, most common are port 7 and port 9. Does your tool state which port it uses?
