mike_
Jul 30, 2012Aspirant
WOL problem on NVX
I am trying to use the WOL function on a NVX If the NAS powers down, either by pressing the power button or using the built in power timer, then the WOL works if the packet is sent within a few min...
Slasky
Aug 02, 2012Aspirant
In my case, both my NAS and my computer that I WOL is on a DHCP reservation. I'm using the ReadyWOL addon on my Duo, and if the computer is switched off and powercable taken out, it won't respond to WOL packets. The NAS is connected directly to my router, while my computer is connected to a Netgear switch of some kind (can't remember model atm).
The router shouldn't flush the ARP info even though I'm connected through a switch should it?
