mike_
Jul 30, 2012Aspirant
WOL problem on NVX
I am trying to use the WOL function on a NVX If the NAS powers down, either by pressing the power button or using the built in power timer, then the WOL works if the packet is sent within a few min...
Aug 03, 2012Guru - Experienced User
I agree that your issue sounds different from Slasky's. I've also seen other posts complaining about WoL with Belkin routers.
mike. wrote: My issue is definitely ARP related as the link light remains on at all times and looking at Wireshark's output the router doesn't know where to send the packet.
I have tried a DHCP assigned address and a fixed address but it makes no difference,
Judging by other posts on other forums the Belkin router is my problem.
