mike_
Jul 30, 2012Aspirant
WOL problem on NVX
I am trying to use the WOL function on a NVX If the NAS powers down, either by pressing the power button or using the built in power timer, then the WOL works if the packet is sent within a few min...
Aug 15, 2013Guru - Experienced User
Hi Dimonira
Thx for sharing your method. Reading through it, it appears to be aimed at allowing you to use WoL over the internet, and shouldn't be needed if the web browser is connected to the local network.
