mike_
Jul 30, 2012Aspirant
WOL problem on NVX
I am trying to use the WOL function on a NVX
If the NAS powers down, either by pressing the power button or using the built in power timer, then the WOL works if the packet is sent within a few minutes of removing the power.
However if I leave the NAS overnight then the WOL function does not work.
The only way to power on is via the power switch or using the power timer.
Is there some sort of backup battery that is failing or is my unit faulty?
I am using the latest release of the firmware.
- StephenBGuru - Experienced UserI see. What they call "ARP binding" is called "IP address reservation" in netgear routers.
When you said static IP address earlier, I was thinking about the local NAS address, not the ISP address (though you did say "external"...)
Whenever you forward ports, you should either use address reservation or assign static local address. So I agree you need it.
Most WoL utilities are designed for local lan use only, and broadcast the magic packets. With those tools you don't need static addresses (or forwarded ports) - but of course you can't use them over the internet.
