ashley8bit
Jul 16, 2014Aspirant
Write Speed ReadyNAS 102
Hello I have had a search through the forum and online and feel I have a speed issue but not sure what to do next. I thought it might be my router so I have connected my MacBook directly to the Rea...
mdgm-ntgr
Jul 16, 2014NETGEAR Employee Retired
What version of ReadyNAS OS are you running?
What disks do you have installed?
What services do you have enabled?
Are you using the anti-virus feature?
Are you using snapshots?
What apps are installed and running?
