ashley8bit
Jul 16, 2014Aspirant
Write Speed ReadyNAS 102
Hello I have had a search through the forum and online and feel I have a speed issue but not sure what to do next. I thought it might be my router so I have connected my MacBook directly to the Rea...
ashley8bit
Jul 17, 2014Aspirant
Hello
In response to your questions please see below:
What version of ReadyNAS OS are you running?
6.1.8
What disks do you have installed?
2 x WD 3TB Red SATA 6Gb/s 64MB 3.5" Hard Drives
What services do you have enabled?
Smb, AFP, readydlna, upnp, http and https
Are you using the anti-virus feature?
No
Are you using snapshots?
Yes
What apps are installed and running?
None
All settings are as they were on day one.
I hope this info helps. Thanks.
6.1.8
No
Yes
None
