str_ta
Sep 06, 2016Aspirant
Writing speed became so slow after upgrade to 6.5.1 #27294735
Hello,
I recently got new RN104 and now I am having performance issue on writing data there.
I put new HDDs for that. (2 of Western Digital Red 6TB and use them as RAID1 ).
Actually I called support and got another RN box and what I saw was
the writing speed was good at FW6.2.0 and FW6.2.5 but once it is upgraded to 6.5.1 the Writing speed become 1/5...
FW6.2.0 : Sequential Write (T= 1) : 65.227 MB/s
FW6.2.5 : Sequential Write (T= 1) : 55.156 MB/s
FW6.5.1 : Sequential Write (T= 1) : 11.533 MB/s
So I think that is FW issue.. but I cannot go back to 6.2.5 now..
I use Windows 7 as client and at RN box, only enable SMB, HTTP, HTTPS ( no Virus Check). set SMB as SMB2 using SMB Plus. Disabled IPv6, Factory Reset already done but no help. Change MTU value also did not help.
Can someone please help ?
With current speed, I cannot use that box for my scheduled data backup purpose..
Thanks so much for the support.
Updating to 6.5.2 and installing an fix to the WSD service resolved the issue.
Looking forward to the release of 6.6.0.
thanks and regards.
- mdgm-ntgrNETGEAR Employee Retired
What's the performance like on ReadyNASOS 6.5.2-T500 (Beta 2) ?
- str_taAspirant
Hi Thanks for the message..
But as long as I see the changelogs, my case is not identified there.. do you think the Beta will fix my issue ?
Well you can't go back to 6.2.5 now, so trying 6.5.2 beta could be worth a try. If it doesn't improve things you can downgrade back to 6.5.1.
