T_R_S
Aug 22, 2012Aspirant
X-Raid 2 Confusion
I am installing my 3rd Ultra 6 - I have the following volume config why is volume so small? Disk space 212 MB (0%) of 2212 GB used Configuration: RAID Level X-RAID2, 5 disks (with dual redun...
vandermerwe
Aug 22, 2012Master
I would say that is correct given that you have dual redundancy and 3 750 gb drives, the 2 2tb drives won't add any more capacity than if they had also been 750gb drives.
With dual redundancy you would need to add 4 disks with increased capacity to vertically expand. Obviously you can't do this. Can you afford to get 2 ( or 3) more 2tb drives?
