T_R_S
Aug 22, 2012Aspirant
X-Raid 2 Confusion
I am installing my 3rd Ultra 6 - I have the following volume config why is volume so small? Disk space 212 MB (0%) of 2212 GB used Configuration: RAID Level X-RAID2, 5 disks (with dual redun...
Aug 23, 2012Guru - Experienced User
The disk models shown are certainly 3 TB. They would show as 750 GB if he was using 4.2.15 or earlier firmware. I think that is the most likely explanation.
vandermerwe wrote: Hi.
I see. Strange.
I assume you factory defaulted with the latest firmware.
Don't take this the wrong way, but are you certain your 3 tb drives are 3 tb, not 750 gb?
