T_R_S
Aug 22, 2012Aspirant
X-Raid 2 Confusion
I am installing my 3rd Ultra 6 - I have the following volume config why is volume so small? Disk space 212 MB (0%) of 2212 GB used Configuration: RAID Level X-RAID2, 5 disks (with dual redun...
mdgm-ntgr
Aug 24, 2012NETGEAR Employee Retired
That's better than what you had before.
It would create the layer with 2TB per disk and then once that's all synced up sector-by-sector then expand to add a layer using the remaining 1TB on the 3TB disks.
