T_R_S
Aug 22, 2012Aspirant
X-Raid 2 Confusion
I am installing my 3rd Ultra 6 - I have the following volume config why is volume so small? Disk space 212 MB (0%) of 2212 GB used Configuration: RAID Level X-RAID2, 5 disks (with dual redun...
Aug 25, 2012Guru - Experienced User
AKAIK you don't need to have all drives to be the same - what should happen is amount of redundant storage is the size of two largest drives.
