obermike
Nov 02, 2011Aspirant
X-Raid 2 Expansion
I have a readyNas Pro containing 4, 1-GB discs set in X-RAID2 configuration. I added an additional 2GB disc and then rebooted, but it only allocated 1GB towards the capacity despite showing 2GB (1863...
mdgm-ntgr
Nov 02, 2011NETGEAR Employee Retired
X-RAID2 is not the same as X-RAID.
Add a second 2TB disk and you will get vertical expansion assuming you are using the default single-redundancy (If using dual-redundancy Frontview would indicate this on the volumes page).
You may be prompted to reboot before vertical expansion will take place.
