adb1
Apr 15, 2015Aspirant
X-RAID and access to data if box fails
I've had 2 Ultra 2 Plus boxes break on me in 4 years. The first time round I put one of the disks in a USB and got the data off as it was basically mirrored. Now I've had the second failure and it'...
KodyStewy
Jul 31, 2015Aspirant
Hello,
I have a Netgear RND4000-100NAS with a bad power supply. From what you wrote, if I purchase the Netgear ReadyNAS 402 and transfer the current hard drives into the new NAS, then I should be able to turn the NAS on and it will recognize the data already on the drives? Is it that simple or do I need to do special steps to make sure the new NAS does not reformat the hard drives, but recognize the data already on the drives?
Jul 31, 2015Guru - Experienced User
KodyStewy wrote:
Hello,
ReadyNAS 402? AFAIK there is no such thing. Did you mean RN204?
If you want to migrate your data to a new OS6 system, you need to coordinate that with support. There's no way to convert the older file system non-destructively. But they can remotely mount the NV+ v1 disks on the OS6 system, so you can then copy the data off (either to USB drives or over the network).
