kjbnz
Aug 31, 2012Aspirant
X-Raid Engine Failed to Start Dual disc failure. #19333472
Hi there, I have a ReadyNas NV+ (V1 RND4000) that was left on whilst I was travelling. During that period I had two drives fail. (First drive 2, then drive 1) When I tried to restart the N...
Sep 02, 2012Guru - Experienced User
If you have multiple failed drives that you cannot clone, then the data is gone. All you can do is replace the failed drives with good ones, and start over with a factory default. I also suggest putting a backup strategy in place.
You can upgrade the NAS now if you like.
