TheWierd
Nov 10, 2011Guide
X-Raid Recovery using PC(Windows/Linux)
I had an NV+ with X-Raid enabled that broke. Now I have brought an Ultra 4 instead and it uses X-Raid2. Netgear support said that you can't plug it in and just go, I have to do a factory reset and fo...
TheWierd
Nov 11, 2011Guide
Well this was a populated part of the forum...
After a lot of searching the web I have found out A LOT of different ways, and 95% of em don't work.
You can do it by connecting it to your PC, booting in to Linux(or Ubunto for example) and using R-Linux.
The bad part is that R-linux cost 80$ and the free version can only restore 64kb in file size :/
Will update as soon as a similar windows program is done scanning the HDD. A free one btw.
