TheWierd
Nov 10, 2011Guide
X-Raid Recovery using PC(Windows/Linux)
I had an NV+ with X-Raid enabled that broke. Now I have brought an Ultra 4 instead and it uses X-Raid2. Netgear support said that you can't plug it in and just go, I have to do a factory reset and fo...
chsu83
Apr 02, 2012Luminary
hi maxblack,
are you able to describe which settings you used in r-studio?
Regards
Chris
Regards
Chris
