TheWierd
Nov 10, 2011Guide
X-Raid Recovery using PC(Windows/Linux)
I had an NV+ with X-Raid enabled that broke. Now I have brought an Ultra 4 instead and it uses X-Raid2. Netgear support said that you can't plug it in and just go, I have to do a factory reset and fo...
andyask
Feb 21, 2013Guide
I successfully recovered data from a lost volume/partition on a Duo V2 with RAID X2 using R-Studio 6.1 for Windows on a WIn7 Pro 64bit machine. 250Gigs of data, 14hours to create image, 12 hours to scan it and 3 hours to restore. The folder structure was preserved. Hope this helps other people (late post I know!)
