dfrederiksen
Mar 23, 2018Aspirant
X-Raid Verticle Expansion Incomplete
Hello, I have recently attempted a Verticle Expansion of our array from X-Raid (6) 12X3TB by replacing with 4X6TB drives. I replaced one drive at a time allowing amply time to resync, verifying...
- Apr 17, 2018
Hello,
I ended up opening a support case with NetGear:
Hi there,
The array was suppose to be expanded automatic, but for some reason it didn't take place so engg expanded it manually.
Let me know if you have any other concerns.
Thank you for the logs though.
Sarosh
yxue
Mar 25, 2018NETGEAR Expert
Is the 6T disk new, or used?
dfrederiksen
Mar 26, 2018Aspirant
They were all brand new.
- mdgm-ntgrMar 26, 2018NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- dfrederiksenMar 27, 2018Aspirant
I have sent in the logs.
- mdgm-ntgrMar 27, 2018NETGEAR Employee Retired
You let your data volume get pretty much 100% full and it has been forced read-only.
Is your backup up to date?
- Sep 06, 2016Retired_Member
