dfrederiksen
Mar 23, 2018Aspirant
X-Raid Verticle Expansion Incomplete
Hello, I have recently attempted a Verticle Expansion of our array from X-Raid (6) 12X3TB by replacing with 4X6TB drives. I replaced one drive at a time allowing amply time to resync, verifying...
- Apr 17, 2018
Hello,
I ended up opening a support case with NetGear:
Hi there,
The array was suppose to be expanded automatic, but for some reason it didn't take place so engg expanded it manually.
Let me know if you have any other concerns.
Thank you for the logs though.
Sarosh
Mar 28, 2018Guru - Experienced User
Normal guidance is to maintain at least 15% free space. Netgear starts generating warning alerts when free space drops below 30%.
dfrederiksen
Apr 04, 2018Aspirant
I now have freed up some space. How do I proceed to expand the volume?
- JohnCM_SApr 11, 2018NETGEAR Employee Retired
Hi dfrederiksen,
Have you tried doing a reboot after freeing up some space?
- dfrederiksenApr 12, 2018Aspirant
Yes. Unfortunately it had no effect and there is no change.
- JohnCM_SApr 12, 2018NETGEAR Employee Retired
Hi dfrederiksen,
It could be that the data-1 volume needs to be removed, but you will need to backup your data first and then we will need to check if it is being used by the data volume or not. If it is shows as already used by the data volume then destroying data-1 could take down the entire data volume.
- JohnCM_SApr 17, 2018NETGEAR Employee Retired
Hi dfrederiksen,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - dfrederiksenApr 17, 2018Aspirant
Hello,
Hi there,
Sarosh
- Sep 06, 2016Retired_Member
