platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
vandermerwe
Aug 28, 2013Master
Are you running 6.1.1 on a Pro or do you have another readynas, I'm looking at your profile.
Do you have a backup?
