platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
vandermerwe
Aug 28, 2013Master
And you are certain that you are on xraid2, not flex raid?
In one of your other posts you have posted pictures of the GUI showing that the disks are recognised as 3tb disks, is this correct?
What does the volume tab show?
