platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
platini76
yes i'm in flex raid... edited..... i'm in XRAID!
volume tab recognise those but wont' expand them it remain as before (when there are 1 500gb and 1 tb and the space was 500gb)
i see in log that there is an error:
I try to launch manually this command:
reply:
Aug 28 23:08:50 ReadyNasPro rn-expand[1890]: Checking if RAID disk sdb is expandable...
Aug 28 23:08:50 ReadyNasPro rn-expand[1890]: Expanding pool data, RAID data-0
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Growing MD array (md127) to 2925416672KB
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: command failed [1]: /sbin/mdadm -G --size=2925416672 /dev/md127
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Trying auto-extend (grow onto additional disks)
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: auto_extend: Checking disk sda...
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: auto_extend: Checking disk sdb...
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Trying xraid-expand (tiered expansion)
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Considering X-RAID auto-expansion for data
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Checking if RAID disk sda is expandable...
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: Checking if RAID disk sdb is expandable...
Aug 28 23:08:53 ReadyNasPro rn-expand[1890]: 0 disks expandable in data
reply:
mdadm: Cannot set device size for /dev/md127: Device or resource busy
Bitmap must be removed before size can be changed
