platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
vandermerwe
Aug 28, 2013Master
I think you may need to factory default and restore from backup.
Could it have something to do with installing 6.1.1 on a Pro?
