platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
Aug 29, 2013Guru - Experienced User
If this is a pro running 4.2.24, perhaps try these suggestions here: http://home.bott.ca/webserver/?p=550
If the disks on the HCL, you can also submit a support case at support.netgear.com.
