platini76
Aug 28, 2013Aspirant
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1 installed on two double disk 500gb after all is sync I have take off one and install one 3tb on bay2 resync.... all is ok, take off also other 500gb and installed othe...
platini76
Aug 29, 2013Aspirant
when in the afternoon I had 4.2.24 I don't see this post and only disable snapshots, then I upgrade and on 6.1.1 I cannot ask to support... :D
now is fine, after a reset complete...
