dannieboiz
Aug 20, 2014Tutor
Xraid2 dual redundant vs FlexRaid 6?
What's the pro's and con's of each? They both seems to be identical if Dual redundant is selected.
Aug 20, 2014Guru - Experienced User
They are separate phases (sequential, not parallel).
dannieboiz wrote: it's still resyncing at the moment. Got about 7 hours to go, does the vertical expansion happen along side with resyncing? Should I wait for resync to complete then worry if I don't see the other 2Tb come in?
Wait for it...
