dannieboiz
Aug 20, 2014Tutor
Xraid2 dual redundant vs FlexRaid 6?
What's the pro's and con's of each? They both seems to be identical if Dual redundant is selected.
vandermerwe
Aug 20, 2014Master
No it doesn't matter, but the facility to use flexraid was I assume intended for scenarios where users wanted something that xraid does not offer, like multiple volumes, JBOD, raid0, raid10.
For your purposes the default mode, xraid , gives you what you need so there is no advantage in using flexraid.
