Crash_HI
May 21, 2021Guide
Can't connect via VPN "The VPN Group list is empty"
Hi, Our user cannot connect via VPN. The client says: "The VPN Group list is empty" The VPN group and user are correctly listed in the Insight web site. I tried removing and re-adding the us...
DamianM
May 25, 2021NETGEAR Moderator
Hello Crash_HI,
welcome to the NETGEAR community!
I would like to ask you to restart your devices so that they can re-establish the connection. Our engineers have applied a fix and it should work fine after the restart.
DamianM
NETGEAR team
Crash_HI
May 25, 2021Guide
Hi,
I also attempted to connect with the client system and it still says the VPN group is empty so it is not working.
Thanks
- DamianMMay 26, 2021NETGEAR Moderator
Hello Crash_HI,
I would like to discuss this case with the engineers and will let you know when I have further information for you.
Have a nice day!
Best regards,
DamianM
NETGEAR team- GlassweaverMay 28, 2021Tutor
Hi Damian,
I received an update from Bryan a couple days ago and can confirm that the issue is resolved for me. For some users, I did have to remove them from the Insight VPN group memberships and re-add them, but the issue for me is fixed.As I iterated to Bryan in my case I had opened, please, pleeeaasssseeeeeeee try to be our voice in advocating for status.netgear.com to be updated next time an issue like this happens. If this were a service affecting issue with a Cisco device, status.cisco.com would have been updated within an hour of issue confirmation. Comparably, Netgear worked on this issue for two days without status.netgear.com having ever been updated.
This makes it impossible to trust netgears status page, and will make many MSPs and in house IT professionals shy away when a page that important can't be trusted. The mere existence of this forum post we're conversign in, and lack of reflected status on that page, is a stark contrast to the worlds of Cisco, Aruba, Juniper...etc.Netgear makes great products, has good support, and, eventually, does fix issues like this. But these sorts of communicatoin issues would be a dealbreaker to any IT manager I have ever known. I'm not sure how the insight platform is going to grow and remain a viable product when netgears idea of communicating issues is to let you poor guys have to answer the same question over and over in support cases and forum posts that are never reflected on the status page.
Anyway, thank you again for all you guys do.
- Crash_HIMay 28, 2021Guide
Hi,
This morning the VPN client was spontaneously able to connect to the router without a problem, and the Insight app VPN diagnostic now shows GOOD. I assume that something must have been going on behind the scenes since I didn't work on this problem yesterday and haven't rebooted the router since they day we were told to do so.
We are glad it is working again,
John
