Crash_HI
May 21, 2021Guide
Can't connect via VPN "The VPN Group list is empty"
Hi, Our user cannot connect via VPN. The client says: "The VPN Group list is empty" The VPN group and user are correctly listed in the Insight web site. I tried removing and re-adding the us...
Glassweaver
May 28, 2021Tutor
Hi Damian,
I received an update from Bryan a couple days ago and can confirm that the issue is resolved for me. For some users, I did have to remove them from the Insight VPN group memberships and re-add them, but the issue for me is fixed.
As I iterated to Bryan in my case I had opened, please, pleeeaasssseeeeeeee try to be our voice in advocating for status.netgear.com to be updated next time an issue like this happens. If this were a service affecting issue with a Cisco device, status.cisco.com would have been updated within an hour of issue confirmation. Comparably, Netgear worked on this issue for two days without status.netgear.com having ever been updated.
This makes it impossible to trust netgears status page, and will make many MSPs and in house IT professionals shy away when a page that important can't be trusted. The mere existence of this forum post we're conversign in, and lack of reflected status on that page, is a stark contrast to the worlds of Cisco, Aruba, Juniper...etc.
Netgear makes great products, has good support, and, eventually, does fix issues like this. But these sorts of communicatoin issues would be a dealbreaker to any IT manager I have ever known. I'm not sure how the insight platform is going to grow and remain a viable product when netgears idea of communicating issues is to let you poor guys have to answer the same question over and over in support cases and forum posts that are never reflected on the status page.
Anyway, thank you again for all you guys do.
Crash_HI
May 28, 2021Guide
Hi,
This morning the VPN client was spontaneously able to connect to the router without a problem, and the Insight app VPN diagnostic now shows GOOD. I assume that something must have been going on behind the scenes since I didn't work on this problem yesterday and haven't rebooted the router since they day we were told to do so.
We are glad it is working again,
John
- DamianMJun 01, 2021NETGEAR Moderator
Hello Crash_HI,
thank you for your feedback, our engineers were able to solve this problem.
I am happy that it works again!
Have a nice day!
Best regards,
DamianM
NETGEAR team- Crash_HIJun 01, 2021Guide
Hi,
The VPN function failed again this morning. Now it says:
"More than the number of routers that can be added to this group"
Insight app diagnostics again shows Test VPN Server connection status: BROKEN.
Thanks for your consideration.
I logged out and logged back in to the VPN Client, and now it has returned to saying:
"The VPN Group list is Empty"
The Insight diagnostic is now showing the The test VPN server connection as GOOD.
Is there another service outage?
Thanks
- DamianMJun 02, 2021NETGEAR Moderator
Hello Crash_HI,
please restart your devices and try again. If it still doesn't work, please contact directly the support: https://www.netgear.com/uk/about/contact-us/
Best regards,
DamianM
NETGEAR team
