CES001
Mar 03, 2022Aspirant
ReadyNas RND2000 v2 & ERR_SSL_VERSION_OR_CIPHER_MISMATCH & RAIDiator 4.1.12 update quest
Hello, I have a ReadyNas RND2000 v2 & ERR_SSL_VERSION_OR_CIPHER_MISMATCH & RAIDiator 4.1.12 update quest: how do i update this NAS so that i dont get this SSL error message ? I can access the...
- Mar 09, 2022
Hi CES001,
Google Chrome, and other internet browsers, has stopped ssl1 support.
So you have to use an older browser to access your device.Doesn't work: Chrome and Edge (I will escalate to add yours).
Currently Working: IE11 (EOL June 2022) and Firefox 97.0 (however it alerts that TLS 1.0 and 1.1 will not be supported in a future release). Pale Moon.
Good day to you,
Valerie D
Netgear Team
CES001
Mar 09, 2022Aspirant
Hi Valerie,
Thank you for your reply.
Ok, i will retain a copy of Internet Explorer for that sense, so that i can access the admin page.
The second part of my question was: is there a way i can update the firmware of my NAS to the latest version without getting these error messages ?
Best regards Chris
CES001
Mar 11, 2022Aspirant
Hi Valerie,
Do you have time to look at my question how i can update my NAS ("is there a way i can update the firmware of my NAS to the latest version without getting these error messages ?") ?
Actually i have 3 identical NAS devices which all need this update.
Can you please help ?
best regards,
Chris
- ValerieDMar 11, 2022Community Manager
Hi @CES001,
Sorry for the delay.
Did you try to use IE or Firefox?
You can use the second method in this article:
https://kb.netgear.com/000049343/RAIDiator-4-Updating-firmware
Good day to you,
Valerie D
Netgear Team- CES001Mar 11, 2022Aspirant
Hi Valerie,
I am using Brave as a browser.
And in the second post i wrote:
"I tried to upload RAIDiator-arm-5.3.13 but i receive an error message. Checking if there is an update from Internet also ends with an error message....."
Question: could it be that RAIDiator-arm-5.3.13 is not the right piece of update i need to use ?
In other words: can you please help me by informing me which version i need to use ? And maybe i need to update it first to a certain software level, and then later to the latest level ?
I really hope you can help me....
Thanks a lot !
Best regards Chris
Updating your ReadyNAS via the Remote option:
- Navigate to Frontview
- Select System > Update.
- Select the Remote tab.
- Select the Check for Update button.
- If a newer firmware is available, you are prompted to update the system. Click Install to process the upgrade.
- Select Shutdown and Reboot device to update your ReadyNAS.
Updating your ReadyNAS via the Local option:
- Go to the support page for your ReadyNAS and click Downloads.
- Download the RAIDiator firmware for your ReadyNAS to a computer that is local to the ReadyNAS.
- Select the Local tab.
- Browse to the firmware you downloaded from the support page.
- Click Install to process the upgrade.
- CES001Mar 15, 2022Aspirant
Hello Valerie,
Can you please help me ?
best regards, CES
