Keyman42
Aug 04, 2020Aspirant
ReadyNAS Duo RND2000 V2
 Can I move disks with data from an older ReadyNas Duo V2 to a newer chassie?  (The older have a power fault.)
- Aug 04, 2020Hello Keyman42 Welcome to the Community :) If the new NAS is exactly the same model as the old one, then you can transfer the disks in the same order to get access to the data, provided the HDDs are healthy. However, if you wish to transfer the disks to a different model, then you should get in touch with Tech Support for the data recovery. See this KB article as an example, should you wish to migrate to the new OS 6. Before transferring the disks or performing any other operation, we recommend ensuring that you have an updated external data backup. With ReadyNAS, it is essential to keep an external backup of the data, to ensure their safety. Kind Regards, Erika NETGEAR Team
ErikaMa
Aug 04, 2020NETGEAR Employee Retired
Hello Keyman42
Kind Regards,
Erika
NETGEAR Team
- Keyman42Aug 04, 2020AspirantIt is not possible to find an exact type. ReadyNAS Duo 212 is availibel. Can that work?? - ErikaMaAug 05, 2020NETGEAR Employee RetiredHello Keyman42, the model RN212 is an OS 6 NAS, so in order to migrate the disks of your RND2000v2, you should contact NETGEAR Tech Support. Please refer to the KB article "ReadyNAS: Migrating disks from RAIDiator 4.1 or RAIDiator 5.3 to ReadyNAS OS 6". Kind Regards, Erika NETGEAR Team
