plingis30000
Dec 07, 2019Aspirant
Readynas nv+
Hi! I have problems clicking on the links in the GUI, and there are no hostname etc presented... See the file... Does anyone know where to start troubleshooting? Best, Magnus
ErikaMa
Dec 10, 2019NETGEAR Employee Retired
Hello Magnus,
So, first of all, I would advise doing a gentle reboot of the NAS. Wait for the NAS to complete the reboot, then try to access the web interface.
If this does not work, try to use multiple browsers after clearing temporary files, or alternatively use incognito mode in your current browser.
We always recommend keeping a backup of the NAS data.
Let me know if any of this helps :)
Erika
NETGEAR Team
plingis30000
Dec 14, 2019Aspirant
Hi!
Thanks for your help! Do you have a manual for how to perform a "gentle reboot"?
Best,
Magnus
- ErikaMaDec 16, 2019NETGEAR Employee Retired
Hello Magnus,
By gentle reboot I simply mean turning the NAS off and on again, by pressing the power button (without abruptly disconnecting the plug or such).
If nothing changes, you might try an OS Reinstall through the Boot Menu. OS Reinstall reinstalls the firmware from the system’s internal flash to its disks. OS reinstall boot mode also resets some settings on your system, such as Internet protocol settings and the administrator password, to defaults. You can check the User Manual at this link for more information.
Please, before doing anything, ensure that you have a backup of the NAS data.
Erika
NETGEAR Team
- plingis30000Dec 16, 2019AspirantOk, I see..
OS reinstall: Will the data on the disk be left, in most cases when doing a OS reinstall?
Best,
Magnus- ErikaMaDec 16, 2019NETGEAR Employee Retired
Hello Magnus,
The OS Reinstall should not delete the data on the disk, as it simply reinstalls the OS.
However, I would underline again that, before performing any operation on the NAS, you should always ensure that you have a backup of the data. This is very important.
If you wish, you can send me the logs via private message, to check if there is any specific error. In this case, I would suggest to upload the logs file in cloud and send me the link.
Erika
NETGEAR Team
