plingis30000
Dec 07, 2019Aspirant
Readynas nv+
Hi! I have problems clicking on the links in the GUI, and there are no hostname etc presented... See the file... Does anyone know where to start troubleshooting? Best, Magnus
ErikaMa
Feb 03, 2020NETGEAR Employee Retired
Hello Magnus,
Sorry for the delay in replying.
I suggest consulting the article ReadyNAS: Volume Expansion, your NAS should be a RND4000v1 with V4.1.xx firmware.
Also, if you check the ReadyNAS Hard Disk Compatibility List you can see that for ReadyNAS NV+ the maximum capacity is 2TB per disk.
Erika
NETGEAR Team
