CES001
Mar 03, 2022Aspirant
ReadyNas RND2000 v2 & ERR_SSL_VERSION_OR_CIPHER_MISMATCH & RAIDiator 4.1.12 update quest
Hello, I have a ReadyNas RND2000 v2 & ERR_SSL_VERSION_OR_CIPHER_MISMATCH & RAIDiator 4.1.12 update quest: how do i update this NAS so that i dont get this SSL error message ? I can access the...
- Mar 09, 2022
Hi CES001,
Google Chrome, and other internet browsers, has stopped ssl1 support.
So you have to use an older browser to access your device.Doesn't work: Chrome and Edge (I will escalate to add yours).
Currently Working: IE11 (EOL June 2022) and Firefox 97.0 (however it alerts that TLS 1.0 and 1.1 will not be supported in a future release). Pale Moon.
Good day to you,
Valerie D
Netgear Team
ValerieD
Mar 16, 2022Community Manager
Hi CES001,
As I explained you, I would advise to use IE or Firefox as Brave has stopped ssl1 support.
You may still get a warning when accessing the admin page but the error will be different and it can be ignored.
For the firmware you should use:
https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
It is the last version available for your ReayNAS.
Good day to you,
Valerie D
Netgear Team
CES001
Mar 16, 2022Aspirant
Thank you Valerie, yes, i am using IE as a browser as an intermediate solution, because i would like to receive normal browser again after update.
Thank you for advise regarding https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc ; i will try it in the near future (in 2 weeks time from now) and i will let you know if i was able to solve this.
To be continued :cathappy:
best regards Chris
