Hannu
Apr 10, 2023Follower
SUGGESTION: e.g. Nighthawk Pro Gaming, Dashboard "Monthly usage"
Add simple options to a) Add e.g. 25GB to plan limit b) Reset Plan limit to a specified value ... on "Billing start date" Nighthawk Pro Gaming, <- included due to restriction on posting. ...
DamianM
Apr 11, 2023NETGEAR Moderator
Hi Hannu,
thank you for the nice suggestion and your engagement . I referred it to the appropriate department so that we can deal with it.
I wish you a nice day!
Kind Regards,
DamianM
NETGEAR Community
