MartinN
Jul 03, 2020Aspirant
One or two issues....
Hi Valérie, You asked me on FB to continue the query here at the community a while back as I'm having quite a lot of trouble with my R8000. This is our latest posts:
You: Hi Martin Nilsson, Yes, that's what I meant. Is the R8000 in AP mode when you follow these instructions? So, if it's not, it's in router mode. Not to have issues, your ISP modem should be set up in bridge mode. If it's not, you have 2 routers on your network and it can create double NAT issues. Valérie, Team NETGEAR
Me: Hi Valérie, I've removed the ISP modem entirely. And my network cable is connected directly to my R8000. Rgds, Martin And thats basically as far as we came. I'm still experiencing lots of troubles with router rebooting frequently, not all possible connections showing (should be 3. The 44, 44 5g1 and 44 5g2) and as it is right now. All lights are there but my connection on the phone only show the 44 5g1. But won't connect. I've even received the error message "wrong password" from time to time... Any way we could sort this out u think..? Kind regards, Martin
- MartinNAspirant
Hi and thank you! :)
Thats right. I'm on fibre and removed the ISP modem and hooked up the r8000 and then the troubles began.... :)
Kind regards,
Martin
- ValerieDCommunity Manager
Hi again MartinN,
Thanks for the confirmation.Then, it should be good to begin with asking your ISP which technical specificities are needed to remove their own router and replace it with a NETGEAR one. Like, some ISPs need special DHCP options.
Knowing this, I will be able to look into the R8000 specificities and understand where the issue is and how to solve it.
Have a nice day,
Valérie D
Netgear Team
