casperha
Jul 29, 2020Aspirant
Ruckus R320 eth connect S350 Series problem
Serial NumberSystem Object OID
| 5GL18B5F00588 |
| 1.3.6.1.4.1.4526.100.4.53 |
| Model Name | Boot Version | Software Version |
| GS310TP | 1.0.0.1 | 1.0.0.12 |
when i plug cat6 cable to ruckus r320 unleashed
just can detect 100 speed full
if i set 1000 and full
also detect same 100 and full
how can i fix it?
- Weifeng_yangNETGEAR Employee Retired
How long is you cat6 cable?
Is it possible to swap a cable for trial?
- casperhaAspirant
just 5m...
no too long..
i have change cable also just can detect 100M...
cable pulg in my computer can be 1000M
How is the switch port speed if connected with a gigabit computer or another gigabit switch?
Or loop the cable to 2 ports of GS310TP?
