Miadi
Apr 19, 2018Aspirant
openvpn 证书问题
说明:出厂固件版本1.0.1.36可以使用vpn。 第一台R9000,升级固件1.0.3.10后,openvpn证书丢失,导致不能使用vpn。 官方客服换了一台新机,并告知我1.0.3.10有bug,可以使用1.0.3.6,于是把第二台R9000升级到1.0.3.6,证书没有丢失,但是过期了,过期时间是1902年。 降级固件也没用,证书不更新,一直是过期的证书。 现在客服没...
schumaku
Apr 19, 2018Guru - Experienced User
Hi Miadi
To the extent I think I understand Chinese your R9000 has a certificate with an expiration date in 1902. No idea what can cause this - seen at least one more similar report some days ago here in the community.
The Nighthawk firmware does usually come with a factory (hard coded) certificate, signed by Entrust, that's the one I have in place since 1.0.3.10 - conclude, there is a problem with some, but by far not all R9000 updated:
This kind of factory certificate is also the reason why older firmware - which held indeed an expired certificate (but not back as far as 1902) - can't be used anymore.
Digging again with the Netgear product engineer.
(Edit:)
If you have a minute - please download the OpenVPN Windows config from your R9000, unzip, and open (double click) ca.crt and client.crt - post the certificate overview and details.
The older certificate set was valid from 25-APR-2014 ... 22-APR-2024, the one I have here on my R9000 is valid from 26-APR-2017 to 21-APR-2037. Curious about yours.
(Edit end.)
-Kurt
PS. Take this as another complaint AbhayB and NaderA - it's ridiculous how unreliable your supposedly leading edge (and expensive!) products are.
Miadi
不知道为什么,附件中文本内容不能发到论坛,发出来就被删掉了。
请你们看一下我的解决方法,帮我完善一下,服务器的时间还是有问题的
