BOEINGNG
Jan 22, 2024Aspirant
为什么wifi6 160MHz测速比wifi6 80MHz慢?
我使用的路由器是NETGEAR RAX50 AX5400,我有一个hp 战66笔记本,他的网卡是Intel AX211 WIFI 6E 160MHz,在我的卧室它测速的结果是下载只有77Mbps,我的宽带是500Mbps的,但在同一个位置我用ipad Pro 2020测速,它的网卡是wifi6 80MHz,测速结果是下载415Mbps,这个是为什么,为什么wifi6 80MHz的测速结果比160MHz快得多?
hp intel AX211 160MHz测速结果
hp AX211链接速度ipad pro wifi6 80MHz测速结果
- BOEINGNGAspirant
I am in China. The router I use is NETGEAR RAX50 AX5400. I have an HP War 66 laptop, and its network card is Intel AX211 WIFI 6E 160MHz. The speed test result in my bedroom is that the download is only 77Mbps. My broadband is 500Mbps, but at the same time In one location, I used an iPad Pro 2020 to measure the speed. Its network card is wifi6 80MHz, and the speed test result is downloading 415Mbps. Why is this? Why is the speed test result of wifi6 80MHz much faster than 160MHz?
intel AX211 link speedintel AX211 5GHz 160MHz speed test resultipad pro wifi6 80MHz speed test result
Key limitation under the China regulations is the fact that the only 160 MHz channel range available is in the channel 32..68 range - and half of these are subject to DFS and/or TPC. The 817/817 Mb/s link rate shown can indicate interferences with other heavy users where we easy see some high 21xx/21xx to 24xx/24xx link rates negotiated elsewhere.
