zhaobo
Mar 10, 2023Aspirant
When will the router actively remove the device?
#Dual-band AX1800 2-Pack (MK62) 我办公室内使用MR60设备,当手机和设备不断增多之后,就会有几台已经连接好的设备断开网络。现在我很苦恼,不知道什么原因或怎么解决。
DarrenM
Mar 16, 2023Sr. NETGEAR Moderator
Have you made sure they are not all connected to one band? Try putting lower-priority devices on the 2.4ghz network.
- zhaoboMar 19, 2023Aspirant
I checked my device, and it was always those devices that could only support 2.4G that were removed from the router. Currently, there are over 60 devices in the environment, and over 40 devices only support 2.4G.
