BibMo's avatar
BibMo
Initiate
Mar 10, 2021
Status:
New
Gesture Control enable/disable
Hi!
Gesture control can be a blessings or curse depending on your environment. I periodically get false gesture detections which is annoying. It would be great if there was a way to enable/disable this feature. Control from the app may be good enough in many sistuations, such as mine. Thanks.
BibMo
6 Comments
  • Hi
    I have the same problem - I have 2 frames and get false gesture detections all the time.
    Mikmak
  • Hi.
    I have the same request for a Meural installed in a little museum. Visitors could enter in menu and stop the slideshow, what we want to avoid.
    Regards
  • Just navigate to Settings > System > Gestures . Here, you can enable or disable a number of Gesture settings. Did you find this helpful?
    DG Customer First
  • +1. Too many false gesture detections. There needs to be a way to disable gesture feedback.
  • I wholeheartedly agree, it's awful and I don't want or need gesture control. Please let me disable it!
