iamSteve's avatar
Mar 04, 2020
Status:
New Idea
Add Dynamic LACP LAG support
The GSS108EPP is almost the perfect switch for my needs with Poe and LAG functionality.  However connecting it to my older GS724Tv3 switch, I have had to set the LAG mode to Static mode as my latest switch the 108EPP does not have Dynamic / LACP functionality.
However I can't connect to my Asus Router in the same way as that only accepts the more robust LACP method.
Please can you advise if you are planning to add LACP mode for LAG setup to the GSS108EPP?
I am sure many would find this useful and allow much better compatibility with other devices.
1 Comment
  • schumaku's avatar
    schumaku
    The very basic switch cores in the Smart Managed Plus don't support LACP - so no luck on that end.
    AFAIK the routers make use of very similar switches - also ASUS - and they use Linux bonding internally. Challenge ASUS to add static LAG alternatively to their routers.
