In the User Manual (page 14), it is recommended that M3 x 20mm screws be used for mounting the router to the wall. This was very helpful but I'd like to see the type of screw head added to the screw info (I found tha the 'Pan head' type works best for me.
I'd also suggest adding the distance between the screw holes (center of hole to center of hole). That, or even an overlay drawing that the user can print and then use the printout as a template on the wall.
Thanks again !
Jeff-
1 Comment
Metric threads for mounting anything into a wall? Wonder what kind of inserts or dowels they have in mind when putting up the specifications for a M3x20 8-/
Measuring the distance between two holes should not be very difficult in the do-it-yourself world. Sure, more critical are the heads, because of the space is limited. Pan-head-like screws should be fine, indeed.
